I'm ready to order an Alky kit myself but haven't decided between Razors progressive kit or the new SMC progressive kit with the newest controller he just released.
Some of the faster guys up here are using razors kit. My brother has been using the smc alky kit on his gn datsun for I think four or five years.. He is running corn alky now and loves it. I am sure some one will chime in. I posted the same thing on this board Last year I think.
Chris.
I got a PTE FMIC and an older SMC dual-nozzle alky setup. Used of course, but they were used together on a 10-second 86 GN, so they should be good enough for me
Also just installed a Walbro 340 and Racetronix hotwire setup, and I have an Accufab AFPR on it's way too, when that gets in I'm also going to throw in the Thrasher I bought from you; should be fun setting up! Myself and Erik's roommate are probably going to bench test the alky pump tonight; I'm thinking installing it this weekend if you wanna come over and help or just shoot the breeze!
I will have to see what is going on with the boss. If you do it on sat might be able to come over for a bit.. When where you thinking of doing it.
One other thing now you are going to need biger turbo like a te-61 with a 3200 stall. Do you have a scan tool at all? You should get somthing like that, or a knock gauge.
Well actually I'm not so sure it'll be going in this weekend, waiting for the instructions from SMC, unless I can find somebody who is positive they know how to install it? If I do do it, it'll be here at Erik's.
Actually I already have Turbolink, and also a knock gauge because I don't feel like driving around with a laptop 24/7
Well, went to Lowe's, Schucks, and Autozone with no success. Went to Midas, bingo! They actually bent me a 3" to 2.5" reducer, for free!
Had a bit of a problem getting the piping in...had to pull the cooling fan, and had some trouble getting it back in as well as the grill, but it's all back together now!
But I do need to either install the alky or cap off the spray line; car runs like crap above ~30% throttle. Sputters and chokes, and I'm positive it's the air bleeding out the line.
There was a bit more lag, but I couldn't tell for sure because above 2psi the damn thing sputtered like somebody with Tourette's. Got done around 5:30!
