RmvBfrFlght
- Sep 28, 2007
Check that pressure switch to see if it is in the closed or open position. That is, ohm out between the terminal and the VB casting. If it is open (NO), then the lockup will work correctly as-is. That is, when the trans shifts into 4th the TCC will lockup as the switch closes (with power on the connector terminal).
If you want to have the ECM control the TCC lockup, the switch needs to be a closed type (NC). The stock switches are NC, so that the ECM sees them go open when in that gear.
The 700R4 used both the NC and NO switches, vehicle dependent. So both are available for use in the 200-4R.
RemoveBeforeFlight
RemoveBeforeFlight
