Dusty Bradford
- May 24, 2001
Cubes always matters. Always.
The nitrous is used before the car leaves the line. It is shut down before the car leaves the line. Nitrous has nothing to do with the car from the point where the car leaves the line all the way to the finish.
If low back pressure were the answer, then you would surely see everyone putting monster turbine sections on their turbos and doing 8s with small heads. That doesn't seem to be the case, though.
Cubes makes more low end torque but not necessarily more hp. I promise you can make just as much power or more power with a 231ci and a 70mm than you can with a 280ci and a 70mm. The difference is the 280ci will come up much faster and won't need the rpm or boost to get a decent 60'.
People do have monster turbine sides on small engines and run 8's. Supra comes to mind
The reason you don't see it everywhere is because nitrous isn't allowed on boosted combo's. Take the nitrous off of yours and see how well it works. If you had to race without nitrous you'd be forced to go back to a smaller turbo and you would slow down.
I have seen a car drop backpressure and instantly need an extra 200pph of fuel. 6 second drag car. So yes that is where your gains are at. It's not magic engine design....it's all about that back pressure.
