QUOTE=John Wilde;2886383]A friend just went 10.78 ET @ 127 on his second pass with a new motor.
The turbo is a 6265, I am hoping this car to has a 9.9 in it.
I will let him post the details if he would like.[/QUOTE]
John: I finally am receiving notifications about threads that I wanted to follow. Sorry I have lagged in responding.
Second run at Noble was 10.78 @126.97 on 93 octane fuel and dual line alky system. Boost was in 20's through 1st and 2nd, creeped up to 22 in 3rd. These are PL computed amounts; gauge shows a # or so lower. Picked up nearly 27 MPH in the back half of the track which pleased me. Car was and still runnng PIG rich and with help from some others, we have decided that the fuel pressure regulator is not controlling the extra fuel generated by the Detschewerks 300lph pump. New pump is on its way and I'm going to fix a leak with the methanol system.
Car spools much faster than I imagined it would and it doesn't miss a beat with the roller cam. Running about 75 in 3rd at half throttle and wanted to see how it pulled in 3rd at that point; it down shifted into 2nd, spun the tires hard and I did the "webble wobble" well into the 90's.
Don't need to do that test again.:biggrin:
Will let you know how this turns out.
Have to get this thing running like a bat of out hell darn quick. We've had 20+ earthquake tremors here in Central Oklahoma since Saturday night, we historically have about 50 a year, with one of them being the strongest ever recorded here and 2 more that are in the top 5. We've also had tornadoes all over the state today with tornado watch on until 4 tomorrow morning. I don't ever recall having one of them in November but we also had our first ever February tornado this year.
Here is my combo.
Engine:
Stock block, bored .030 over, RJC girdle ARP main bolts
JE 9:1 forged pistons with ARP rod bolts
GN1 forged steel, long stroke crank
GN I Forged steel “H” beam long rods
Champion Ported Iron Heads
DLS 218/218 Camshaft
T&D roller rockers, 1.55 ratio
SS headers
PT 6265 turbo with “S” cover, heavy duty actuator and turbo saver
Terry Houston 3 1/2" SS downpipe with test pipe
Cotton’s 3” dual exhaust system
RJC boost controller
Hemco 62MM plenum
Jay Jackson 62MM throttle body
CAS V2 front mount intercooler
Seimens 80# fuel injectors
Deutsche Werks 300 LPH fuel pump, hot wired
Billet adjustable fuel pressure regulator
Alcohol injection system Razor
Cold air intake system with 4” RJC MAF pipe
GM aluminum radiator
Carter high volume water pump
Billet valve cover breathers
Aluminum valve cover spacers
Billet thermostat housing with 160 thermostat
TurboTweak SD chip
Powerlogger and PLX WB O2 sensor
Taylor 10mm ignition wires
Accel coil pack
Autolite 23 R plugs
Transmission and Driveline:
GM 2004R built from PTE’s catalog
PTC, 9.5 Non-lock convertor with 3000 RPM stall
B&M transmission cooler
Drive shaft loop
Moser axles with TA girdle and aluminum differential cover
Suspension:
5 Point roll bar with removable side and rear cross bar
Body bushings, lower and uppers
Rear "X" braces
Front braces, upper and lower
Air bags
Boxed, rear upper and lower control arms with polygraphite bushings
Bilstein shocks
ATR rear sway bar
Polygraphite bushings on front sway bar
![P1010019.jpg P1010019.jpg](https://turbobuick-data.community.forum/attachments/121/121962-fdba08243f9eed50f13a2438c36e42ed.jpg)
![100_0701m.jpg 100_0701m.jpg](https://turbobuick-data.community.forum/attachments/121/121963-7dad93b0c3ffeb62d0caa5572ffa2b72.jpg)
![DSC00443.jpg DSC00443.jpg](https://turbobuick-data.community.forum/attachments/121/121964-9d477c53cb76fc29c26d28e758de35fb.jpg)
![DSC01153.jpg DSC01153.jpg](https://turbobuick-data.community.forum/attachments/121/121965-e097071d82ebd080ac6c76c8a1036cb2.jpg)
