TexasT
Texas, Where are you from
- Sep 10, 2002
I've run the next set of tires on wheels that were drilled with out putting the screws in. If you are running tubes I would recommend the screws be reinstalled but going tubeless I would put a shoe polish stripe on the tire at the valve stem to see if the tire is moving on the rim. If it is the screws might need to be reinstalled.
Glws
Glws
