Trying to iron out all the bugs after the rebuild. The tranny seems to be shifting way too soft. Softer than it did before the rebuild. Ive adjusted the TV cable sleeve all the way back as far as it will go to the firewall and still open the plates all the way and its still a weak shift. With the rebuild i put a 2800-3000 tophat converter in there. Would that change things? Am i setting the TV cable wrong. I can see two notches on the cable. Seeing more notches means harder shifts right?? Please help.
Dan
Dan
