Transmission coolers........
cooler
B & M Super Cooler, In Jegs, 1/2 in. female pipe thread. Hook it up with solid metal lines, works great. I have 2-- one for trans---- one for eng oil.
B&M Super cooler here too.
Mounted in front of the radiator.
Thanks for the response guys, do any of you run a front mount and where did you mount the cooler. I will look in to this super cooler. I also read a post by bruce (we4) that said to use a stacked style cooler, any idea if the super cooler falls into that range. Again thanks for the response.
Zak
Supercooler here too. Best flow and best cooling for it's size. I also accidentally did the "run over the cooler" test (don't ask) and it didn't hurt it
