Prices do not include shipping unless otherwise noted. Pics available for ~ all; email turbotk2001@yahoo.com
-Comp Cams 224/224/110 extreme street solid roller cam:
4871 extreme street lobes, .360" lobe lift, 224 dur @ 0.050", 147 dur at .200". Cam nose set up for the Danny Bee/Duttweiler bronze thrust plate, lobes custom bead blasted per Ruggles recs, also custom cross drilled in the thrust area to positively oil the thrust plate on both sides. Less than 1K miles on it. (~ $350 new plus custom machine work) $225.
-Roller valve springs, Ti retainers, 10 deg locks, spring cups:
Competition Products #2125, "super clean" chrome silicon dual, 1.50" OD, 1.10" ID, ~ 475 lb/in, 190 lbs @ 1.85", 235 lbs @ 1.75", 500 lbs @ 1.20", coilbind at 1.060" (~ $70 new)
Comp Cams Ti retainers for above, 10 deg locks, spring cups from Champion Heads. All less than 2k miles. $75 for all.
-1.75 ratio T&D roller rockers:
For the GN1 heads with the T&D individual rocker shaft per cyl setup (one rocker pair per shaft). Good for flat tappet cams. These are the 12 complete, individual rocker bodies without the shafts, for anyone wanting to upgrade their 1.55 or 1.65 rocker set. About 4k miles on them. These are over $50 ea if ordered through CV Products, over $600 for all 12. $350 for the complete set of 12.
-Pushrods:
Several sets, including 9.000" long Manton Racing 4140 steel super HD pushrods, 11/32" straight for the intakes, 3/8" to 11/32" single taper for the exhaust. Have the correct ball end for T&D rockers. These are very nice and over $300/set of 12 new. $200.
4 others sets of 5/16" of various length, including one set of Comp Cams 8.850", one set of Comp/ATR 8.750", etc. Ask for other lengths. $25 ea set.
-Comp cams 224/224/110 solid flat tapet cam:
VG condition. 0.312" lobe lift. About 4K miles on it. Very good high perf v6 cam. Went 133+ mph at 28 psi boost with 235"/GN1's combo. $30.
-Stock '87 GN/T cam:
VG condition. About 20K miles on it. $30.
-Stock '87 GN/T D5 torque converter:
VG condition. Never locked up at wot. Never faster than 12 sec et's. About 20K miles on it. $80.
-Pushrods:
