twilight sentinel
Does anyone know where to find one of the little dash mounted grilles? When I replaced my forward dash piece with the speaker grilles, I cracked one of the legs off of the dash mounted grille that holds the sensor. Anybody know a GM part number for this piece?
Wrap the little grill with tape and it will pop back in and look fine. I had to do it for the same reason.
I have a NOS one at home in the wrapper.
I will look up the number for you.
I used the tape trick on the one I broke, RTV would work too.
I wrote that article, here it is:
Replacing Body Mounts
I remember there was one minor error in the text, but I can't find it right now. I'll look again. :D
I've added TS to 2 cars including my GNX. Works great. I highly recommend using BFH's overlay piece because it looks 97-44/100 % factory and saves you the agony of cutting your GM overlay. Use a heat gun to get yours off carefully.
Mike [:)
What is BFH overlay? Thanks
