You would energize the brown connector with a wire that you would connect to the positive battery terminal. Or you could get electrons from the connector to the under hood bulb. If you uncap the fuel rail you could drain the gas tank this way. As for the green plug, you could run an after market tach to it and mount it on the steering column like the racers do it. Does this answer your question?
