Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
We suspect the currently installed valve springs are not up to the task. The engine is experiencing knock at about 5100 rpm. No tune, octane, mechanical problems can be found. Smooth power comes on strong though the rpms with no skips, pops, hesitation or audible noises. Power seems to taper off soon after the knock fades and rpms go higher. We expected to have power still being made to at least 5800.
The single wind springs tested 130lbs @ 1.70" install height. We do not know the brand or complete specs. These springs are in nicely ported/polished iron heads, larger intake valves and clearanced for roller rockers. Lifters are Morel regular style roller.
Billet roller cam specs according to paperwork: duration 270/264, 214/210 at .340 lift, lobe sep 113, lift x 1.6 ratio .544/.544. Currently has 1.65 roller rockers. We do not want to switch to bee hives. What valve springs would work correctly with this setup? Thanks.
