Toby_Goodmk
Test Fit officianto
- Dec 9, 2011
Going to be putting this setup on my 84 GN this weekend and next. Double adjustable Viking coil overs on all 4 corners with 400lb rate on front 225lb on rears, umi upper control arms with the taller ball joints, umi lowers, umi rear lower and upper as well as new bushings in the ears of the rear end. Going to be running GNX wheels with 245/50/16. I think giving it a 2 inch drop will not only make the appearance better also make handling quite a bit better as well.
Anyone out there have a similar setup with coil overs on all 4 corners? What are your thoughts on the setup and the functionality and adjust-ability of the coil overs?
