Chevman2448
- Nov 15, 2013
Cool! This beats buying a gauge.
Not sure I followed all of the question?:
I would tap into the output of the MAP and display PSI
The output of the MAP is in volts and would have to be converted to [volts that numerically equal PSI] for the gauge to display correctly.
I havent messed around with installing it yet. Its been too cold to mess around with the car and its the holiday season so I havent had time to install it. I will post my results when I go ahead with the install. Im sure ill have more questions as I go.@Chevman, it fits fine, or did you have to trim the tabs on the ends?
Sent from my A/S8 using Tapatalk
Just finished my install today and wanted to post a pic. Even though it doesnt really look like it in the pic, the display is pretty dim through the 5% tint so I think Im going to swap it out with some 15 or 20%. Pretty cool and thanks again for the post and idea!
forgot how do you wire the 3 wire ?
