What pump to use on mild cam and 55lb injectors GN/ 109 block?
Been told the 255lph pump but seems like there are a couple of different versions..
Thanks,
Joe
You'll likely get several suggestions and Walbro is a sound choice thought many have been disenchanted with the brand for various reasons. DeatschWerks now has a 255lph pump and some have even used their 340lph with stock lines without problems. If a 255lph is all you think you need then my suggestion would be the DeatschWerks DW200. 3 year warranty and E85 compatible should you chose to switch in the future.
