blipmode188
- Jun 28, 2007
Seems like these cars are very finicky. Anyway I have a new problem that just cropped up.
It most likely isnt related to the other problem below but just another sideline issue.
Took off the K&N filter for a cleaning. Replaced it and also plugged the mat sensor back up.Took it out and it threw a error code 23 on the scan master
Bigger problem that I have and this one happend before any of this, the car and boost work fine when you take off. By the boost gauge (not the factory one) it shows around 14 or 15 psi.
Then it just flat lines, doesnt shift and the boost stays flat, car does not go any faster.
If I left off the gas for a split second, it seems to shift and then the boost comes back on and it resumes to take off very fast again.
If you just drive the car normal everything shifts like it is supposed to, i.e it shifts through all the gears no problems.
Its is only when you jump on it if that makes any sense ?
Any ideas of what to look for ?
Incidentally this car is primarily stock, stock turbo, maf etc., does have a TT chip though.
Thanks Steve
Thanks Steve
