What stall do you run with a TE45A?
1KWIK6
UNDER PRESSURE!!!
I just ordered a TE45A from John Craig today. Most mods are in my sig. This car will be 50/50 Street/Strip. I plan to use one of Bruce's 9X11 lockup t/c's. The heads and intake will be Champion ported stockers and the cam will be a SP 204/214. I was thinking 3,200-3,400 stall?
TIA:cool:
Same here i run a 3200 from bruce,with a te45a and love it.No spool up issues, @ the track it will flash to 3600 leaving the line.:)
I think a 3400-3600 is recomended.
I run one of the PTS 9x11's with my TE45a.
Stall is completely dependent on boost.
Mine will stall at 3200lbs at 5lbs
3600 at 10lbs and approx 4200 at 15lbs.
I ran a Art Carr 9" N/L 3400 stall with a TA66 from precision. The car would 60ft low 1.5's all day long with a 12-13lbs launch.
Hope that helps.
Thank you for the helpful replies!;) Looks like I will probably be better off with a PTS 9 X 11 l/u that stalls 3,400-3,600.
Thanks again!:D;)
