pacecarta said:guess ill be spending the day in the garage changing out my gears ...not
Might as well throw in a set of 3.08's. They must be even better than 3.20's
SignUp Now!pacecarta said:guess ill be spending the day in the garage changing out my gears ...not
So if i go with a set of 2.56 gears i should run 8's?![]()
what!! now i have to change rims??
HelloBozos said:Least you have a turbo that will produce the numbers i mentioned,I too own Gt71,anyone reading this under a 55 turbo,Don't worry about it..
I am a rocket scientist (literally) and I still don't follow that logic.80's car, 80's gear, 55mph national speed limit at that time,Speedo only goes to 85,An now you doubled the HP (over the block limitations), no rocket rear end scientist needed there..8^)..but by all means add set 5:56's an 14 inch rim,,"Nothing" Will touch you the first 60 feet..
I am a rocket scientist (literally) and I still don't follow that logic.![]()
brian (bison) and paul (pacecarta) let this one go. we all need you two guys for all the knowledge that you have and your help.in your case ,Apollo 12 vs Space Shuttle...Forgot Rocket scientist don't know crap about cars...lol
his name says it all BOZO and i recongize that amusment park thats BIZZARRO World.
Isn't most highway roll racing 60-130 anyways?
