Sorry for your accident . I have an 88 mitsu. pickup with a 76 turbo 3.8 and turbo 350 trans . The truck came with a 3.90 rear end that I can't break , and more than enough brakes to stop me . I used every thing from the regal , Rad. fan shroud , eng. trans., crossmember,and drive shaft yolk ' The truck has been a daily driver , a tow truck ( does better than you would think ) And sleeper , Fun passing some hot rod while pulling a trailer kind of fun .The whole rig weighs about 2,600 lbs , and has lasted for over 18 years .I believe most of the other Jap. trucks could be used, for a different body style . The bad : Low gears and low profile tires cause high rpm highway speeds ( spare set of tall tires for trips ) Problems in translation A/C lines , GM compressor to Mitsu. condensor, A/C shop custom lines were cheap . Buick oil and temp. to Mitsu. gauges . Center of temp. means its hot should run close to cold Oil light goes on and off as it should .Other wise you couldn't tell it from any other Mini. inside or out . I love my truck hope you find one you'll like too. Bobby .
