Who is spraying alky on top of E85?
TT/Ameasap
The White Blur
I just got my car running on the corn and still have My alky hooked up. I'm at 16-17 psi boost currently but will be turning it up around 22-23.
Anyone actually sprayed alky on top of the E85?
For 22-23 PSI I can't see needing alky too. That being said a member "blackmonte" did. I haven't seen him on the board in a long time though.
Well, I am at 65% IDC with base Fp at 46. TT chip at WOT is at +20% and AFR is 11.0-11.5 On 17-18 psi boost. I seemed to be running out of room.
I talked to Eric and he's going to add some fuel in the chip.
Yep
Mad respect for you man. In terms of tuning, it means a lot getting the nod from you.
Im going to keep adding fuel and boost till 25psi and then start creeping timing up from 18 to 23-24°
A little off topic but are you using the built in voltage controller in the FuelLab pump? If so, how are you triggering it? Thanks, Scott
I am not using it yet. I wanted to know the pump works well without it first. I have no jumper wire on the pump now, meaning it is at max output. I will eventually hook it up and trigger it by boost.
Overall you're happy with it though? Seems like a great product but not much feedback on it out there. Thanks, Scott
Ya, so far I like it... IIRC, NCturbo on this board has the same unit and likes it too.
I mounted mine outside the car on the tire tub with rubber isolators...I put a car cover inside the tub to dampen the sound a little and I can barley hear it with the car running.... Inside and out. When I connect the controller, the pump will stay on the low setting for around town and activate the high output when in boost. The noise should be reduced even more. I just can't stand noisy fuel pumps.
18psi boost 24* timing AFR is 11.0-11.2 wow!
I can't imagine 25psi !!
Alky????? What's that?lol.... I'm draining the tank tomorrow.
Just an update:
I, in fact, did not drain the alky and decided to use it.
I now spray alky on top of the E85 ( still experimenting ) but what a difference is has made. Like I said, I am still experimenting with it, so I dont want to misinform anyone, but I want to get some good logs first.
