I have been working on a customer car for a few weeks. Came here in bad shape. 100% stock!:biggrin: 46,000 miles. Ran like a turd. Fuel pump went out in the driveway!:biggrin: Here's the new parts list....Fuel pump(walbro) and hot wire kit, fuel filter, new 42lb injetors, RJC power plate, LT1 MAF sensor with translator, new crank sensor, new 02 sensor, scanmaster, 3" up pipe, 3" maf pipe with K&N filter, new vac lines, new plugs and wires, TT chip burned for the setup. Car runs like crap till the boost comes in. When the boost comes in it clears up and pulls well. Scanmaster numbers all in check. Drives on the highway like a new caddy. Fuel pressure regulator is stock.
38psi line off. Stock boost control but is at 14psi WOT. Knock is inconsistant. 02's 774 no knock....02's 824 4.2 knock.....02's 800.....no knock. Not enogh data there to say. I took out 2 degrees of timing out WOT and added 10% then 20% of fuel and knock is present then not. Put timing back to where Eric had it burned with the 20% fuel and the same occurs. Only thing I haven't check is cam sensor. Any ideas?? Every run is different so data is inconclusive.
