trading t/a
I'm Angry!!!!!
- Aug 6, 2001
Strange thing encountered recently. My o2's at idle are 000mv. Cant understand it. When under load it's fine, o2's cycle, cross count cycles. 16 psi on 93= 2* or less of knock(sometimes spikes more depending on how hard the transmission shifts).
Notice that when the o2's go to 000 it runs really rough, the tps doesn't react when I step on the gas, cross counts don't move until I hit the pedal more than half way. IAC stays at 0.........
Readings: INT-128, BLM's-135to145(varies slight driver's side exhaust leak), FP at 43psi static, IAC 0, o2's 000mv(under partial load readings cycle from 200-800mv)
I've tried 3 o2's (Delco, Bosch and Standard), 2 known good tps sensors, 3 known good ecm's, 2 chips(a turbo tweak and extender chip), checked all grounds.....
Any ideas?
Tomorrow if I can I'll through in some toulene(octane) to see if the little bit of knock goes away. Other than that I'm stumped....
Started after It accidently drank some 87 octane when I wasn't looking. No tell tale signs of any hg problems, gotta do a compression and leak down.......
Any ideas?
