04 Denali instrument panel help
turboclam
All guages stopped working (froze) and the digital stuff went dark all at the same time. Anyone have any idea? Thanks!
I believe those are good symptoms of a faulty ignition (the electrical portion) switch. I've been out of that line of work for several years and may not be remembering correctly. I think the cluster is the 2nd culprit to check.
Its probably the cluster. There is a mileage limitation of 80,000 for recall.
