Details of the run:
60' 1.62
330'
1/8
MPH 99.7
1000'
1/4 11.05
MPH 124
Screen Name or Car Number Here
EMPTY WEIGHT:3565
BLOCK:stock
HEADS
ort matched, refurbed 200k mile valves w/3 angle valve job
CAM: 206/206
TRANSMISSION:len freeman's 9 sec capable 2004r (performance transmission las vegas)
TORQUE CONVERTER: art car 3500 stall non lockup
DIFFERENTIAL: stock
INTERCOOLER: tony dequick front mount
THROTTLE BODY: stock
RJC POWER PLATE:yes
INJECTORS:83 lb
THERMOSTAT: restrictor
TURBOCHARGER:turbonetics t-72 bb
VALVE SPRINGS: small block chevy replacements
MAF:no
DOWN PIPE:custom external gate dp by qualifab inc
EXHAUST: atr single
FUEL PUMP:red armstrong xp
FUEL PRESSURE REGULATOR: red armstrong
FUEL PRESSURE:40 psi
ALCHOHOL INJECTION
n the car but not used (yet)
PROPAIN INJECTION:no
NITROUS:no
AIR FILTER AND AIR INTAKE:4 inch inlet k&n and flex hose
TIRE DESIGN, SIZE & AIR PRESSURE: hoosier qtp 26x11.5x15 13 psi
AIR BAG(s):no
SUSPENSION:stock
SCAN TOOL:no
FUEL:c-16
CHIP: acell gen7
CHIP TIMING:18 degrees
KNOCK RETARD:no
OXYGEN SENSOR VOLTAGE: air fuel is around 11.0
EXHAUST GAS TEMPERATURE:1500 deg
TRACK ELEVATION:2200 ft
TEMPERATURE:70
PEAK BOOST:26.3
BOOST AT LAUNCH:15 psi
MILES ON THE CAR/ENGINE:196k 56k
			60' 1.62
330'
1/8
MPH 99.7
1000'
1/4 11.05
MPH 124
EMPTY WEIGHT:3565
BLOCK:stock
HEADS
CAM: 206/206
DIFFERENTIAL: stock
RJC POWER PLATE:yes
INJECTORS:83 lb
MAF:no
EXHAUST: atr single
ALCHOHOL INJECTION
NITROUS:no
AIR BAG(s):no
SUSPENSION:stock
SCAN TOOL:no
FUEL:c-16
CHIP: acell gen7
KNOCK RETARD:no
TEMPERATURE:70
PEAK BOOST:26.3
