1.770 valves??
MANLEY severe duty
part # 11503 exhaust valve 1.500 dia.
part# 11504 intake valve 1.775 dia. (intake valves are pro flo shaped)
I have a complete new set of 11503 and 11504 Manley valves if you are looking for some.
Thanks for the replys guys.The Manleys are 1.775 I need a few 1.770 to fix a set of heads.I found this on GNTTYPE.ORG"Valves, Intake (TRW) V3124X 1.770" But the # is no good.The valves I have are completely flat across the bottom unlike the Manleys that have a dish.Does any know what valves I have?? Thanks for the help,Scott
I'm supposed to have '" FERREA'S" in the used set of heads I have, just took a look at them, both valves are flat.
That is correct, they are flat, no "tulip"
Others can probably get them for you. I just ordered a set and it was right at $160 for a complete set of Ferrara SS.
Don't know if this will work, but Pontiac used flat 1.77" exhaust valves on its 400 and 455 motors for many years. There may be a valve with proper height that is similar enough to use in your application.
