Turbo Keith
TURBO KEITH
- Sep 16, 2015
When does one need a spacer and what is its purpose ? Thanks Keith
SignUp Now!It is also used to gain more height so that the throttle body's IAC clears the MAF pipe. And some believe that it helps to direct air more downward towards the runners because it raises the back of the plenum high pressure area. Others believe more volume is good for power. Kinda doesn't make sense because the entire intake north of the intercooler, including the throttle body and up-pipe all becomes plenum at WOT.When does one need a spacer and what is its purpose ? Thanks Keith
Good point. I have had a fiberglass Kirbans hood for years. Even back when I had a factory engine set-up. I may not have had as much space above with a factory hood.You might find a 1" spacer puts your vacuum block dead into the hood liner. I have poly bushing and my 1/2 spacer makes the plenum's rear and the block leave a mark. The vac block scratched hell out of my large '6'..
Most people that need to use a 4" MAF pipe use the 1" plenum spacer. However, it is also a nice clean look if you don't need the extra room for the larger MAF pipe. Get rid of the vacuum lines on top of your throttle body.When does one need a spacer and what is its purpose ? Thanks Keith
Tried uploading a picture but it wouldn't let me. Any way it's a nice clean look and you don't have to drill into your intake.When does one need a spacer and what is its purpose ? Thanks Keith
