- Sep 21, 2018
well I guess I was wrong ....that is how I have seen them run....be kool to see and air flow test each way....see if any measurable difference....
SignUp Now!I honestly dont think we are wrong.well I guess I was wrong ....that is how I have seen them run....be kool to see and air flow test each way....see if any measurable difference....
cruz performance offers an angled spacer now to get rid of you rubbing issueI had a one inch spacer, but it made the up pipe hit my Hoodskinz hood pad.
I was doing some other stuff and went with a half inch spacer to avoid the hood pad rub. That worked for the hood pad rub.
At the same time, I installed the RJC power plate on top of the intake and under the spacer. I thought that was what the directions said, though I cant find them online.
To be honest, I feel I may have lost some low end power. I used to be able to light the rear tires off at will, from a dead stop or at a 30/40 MPH punch.
Doesn't happen anymore. Did I do it wrong?
Got one of those Cruz angled plenum spacers on too, but my HR Parts motor mounts raise the engine by 1/2”, so To gain some extra clearance I installed acruz performance offers an angled spacer now to get rid of you rubbing issue![]()
nice!! info sir!!Got one of those Cruz angled plenum spacers on too, but my HR Parts motor mounts raise the engine by 1/2”, so To gain some extra clearance I installed a
2-1/2” up pipe on my Precision SLIC & also had 1” removed from it & bead rolled again.
Fits like a glove now with lots of hood clearance for my HoodSkinz Hood Liner![]()
Can't say for sure if it would make a difference one way or the other but it would only take a few min to swap it around and find out...I had a one inch spacer, but it made the up pipe hit my Hoodskinz hood pad.
