109 block and crank
Mike E
Mr. Badwrench
I've been using this as a mockup block, but now it's just in the way. Pickup only.
109 block .060" over freshly machined with new cam bearings. $75
Crank, it's probably an NA crank becasue I don't see any rolled fillets. cut .020" on the mains, .010" on the rods. comes with FM main bearings. $75
The crank is currenly installed in the block and a set of 8445 heads are bolted to it. $150 and I'll include the heads and oil pan.
Other than setting the crank in, yes never been assembled. I'm in Hendersonville, TN which is 20 min. north of Nashville.
