109 engine and a few misc parts
limitedv6
Stage 11 in the work's
109 bore is 3.840 this motor was running when pulled out and when i tore it down i found 2 sleeves in it. The machine worked was all checked and bearings replaced it has a 010/010 turbo crank, turbo rods, hyperutetic pistons arp rod bolts, arp main studs, and arp head bolts. The heads are a set of stock iron heads with 100# springs and the cam is a stock cam it also comes with flywheel, balancer, oil pan,front cover with a oil pump booster plate setup. The engine also has a diuble roller timing chain and roller cam button and valve covers. This is not a race motor it would make someone a good driver motor 1500.00
Chrome turbo cover 125.00
Stock turbo cover 75.00
Alluminum radiator has no coolers 150.00
Alluminum griffin radiator with both coolers 225
Te-60 still on car no issues at all 450.00
Ptc 10 in lockup converter 400.00
Real art carr 9 in converter 400.00
Chrome altenator 150.00
Power glide w/ trans brake 1000.00
72# and 83# injectors 2 sets each seimens 200.00 a set
H & R uppers and lower also bennett upper control arms
Allumimum rearend cover with the load bolts like ta
Msd plug wires 8mm, jacobs wires 8mm and magnacore 10mm wires 40.00 - 70.00
Stock electric fans good condition 75.00
Stock tensioners 125.00
Auto meter phantom tach w light and recall a black face auto meter tach, liquid oil temp, oil press, and water temp.
Vdo oil and water
Please text or call and if you dont see what you need let me know as i may just not have it listed.
Thanks Bo
270-300-8046
Pics of the chrome alternator. How long have you had it? How many volts?
"Alluminum radiator has no coolers 150.00" How many miles and condition on this radiator? Also, how much to ship to 06016 area code? Thnx!!!
I am located in elizabethtown ky. I dont know the miles on the radiator for sure as it came out of a car i purchased used. I got the altenator about 1 1/2 years ago and it is factory 120 alt specs. The rearend cover i would need 100.00 for and not sure which control arms pics are needed the they are the regular H&R bars liwers are like new and 240 new i will take 200.00 the bennett uppers i will need 125.00 the rearend cover looks like a TA cover and is in great shape i cant get pics up for some reason rite now. The turbo i think i have sold but it is still on the car and i think it is a 63ar i will look tomorrow.
Please text me or call 270-300]-8046
Guys i cant get my pics to upload if you will text me your number i can send the pics to you no problem, as i stated in my last post please text or call the number below thanks.
270-300-8046
