114 Race gas chip question
cwelk87gn
XCELR8S
I have a 114 race chip and will be running Phillips B32 112 octane fuel. Any suggestions on how much boost I should be able to get away with? I just need some sort of base line. :D
I could be wrong but,,,,
That B32 is 110(m+R/2) which is 106m+114R/2. I bought a drum but decided it was a little low in the motor octane rating(which is the most important for our cars). If you use it just start low~18 psi IMO and add boost from there. I bought a drum of TT114(same as B33) and ran 22 psi w/ a 26 deg chip and 0 KR. Would probably take 24-25 psi psi without a problem! :D . I'll know soon!
Good luck,,,, Ross L
