11's possible?
OneLethal87GN
R.I.P. Lethal GN
My car should finally be back on the road within the month. With my combo I plan on running a street chip and as much boost as 93 and alky will give...hoping for low 20s with @20 degrees timing. I don't plan to run it at the track, but do want to have the power to run 11's if it ever does go. What, other than my combo, do i need to add?
My combo: TE-63-1, ESP f/m, 009s, ATR 14" ram air with 4" solid pipe from MAF to turbo inlet, ported heads with 1.77/1.50 valves, 206/206 Comp Cams, .030 over engine with forged pistons, SMC single stage alky kit, 3" ATR downpipe with 3" hi-flo cat and 3" single shot exhaust, adj. regulator, and Walbro 307 pump. I have other small stuff, but this is the major stuff that does the most good.
Watch thos injectors. I'd go bigger just to be safe. Other than that you should have no problem. I went 11's with much less than you have.
44, Front mount, blue tops, SMC, etc.
Ditto on the injectors. Also maybe upgrade to at least a Walbro 340. Good tunning, and 11's should be no problem.:D
I guess that depends on how far from the finish line you plan on throwing it in neutral, and wether or not you plan on hitting the brakes. I say if you dont coast more than 300' and dont hit the brakes then an 11 should be pretty easy. Launch it good and try to pull some good mph in the 1/8th and the 11's will come easy.
Seriously though 115 mph should be EASY with your set up. Get a good launch, get 1/8th mile mph in the mid 90's, and you'll go WAY into the 11's. Get crappy launches, 1/8th mile mph in the high 80's/ low 90's, run 118 in the 1/4 and you got a 50/50 chance for a low 12 or high 11 time slip.
Jason
