Darth Fiero
3800 Series II Turbo
- Jan 12, 2003
Finally, low 12's. Last year, I went 12.79 @ 106mph but that was with a rediculously small intercooler and 2.5" exhaust. Earlier this year I upgraded to a modified stock GN intercooler, 3" mandrel bent exhaust tubing, and a Magnaflow wide-open muffler. First, let me start by saying that I cannot say enough good things about this muffler. This is the BEST muffler I have ever used, and it is quieter than a Flowmaster, Dynomax Super Turbo, or a Holley Terminator...speaking from personal experience. With it's straight-thru flow design, I don't see how it can't flow better than any chambered muffler. But enough with the advertisement...
Anyway, here are the mods to the car:
-approx 3000lbs without me in it
-3800 Series II L67 shortblock
-mildly ported L36 heads
-Camaro L36 intake
-36lb L67 injectors
-stock cam and rockers
-stock GN turbo with ported exhaust housing
-GN intercooler w/ modified inlet/outlet
-3" mandrel bent exhaust w/ 3" magnaflow muffler
-4T60-E trans w/ 3.33 final drive
-95 Bonneville PCM with custom tuning done by me
here is a link to the timeslip: http://dtcc.cz28.com/3800turbo1238.jpg
1.784 60' using BFG 225 55/16 Traction T/A H-rated
12.381 1/4 mile ET
110.03 MPH
93 octane pump gas w/ Klotz hitrate octane boost; 15lbs max boost launching at 2lbs. 20 deg timing at WOT with 0 KR. Shifting at approx 5600rpm.
The MPH looks slightly low to me which tells me the engine is making a lot more TQ than HP, but on a stock cam what do I expect? I have heard that Erson will regrind a stock cam to just about any spec for less than $100 so I might have to check them out.
-Camaro L36 intake
-36lb L67 injectors
12.381 1/4 mile ET
110.03 MPH
