13,500 86 GN for sale
Thumper
608
42
28
Kentucky
Selling our low mile 86, 13,500 miles.
5 time gold winner in concours at gs nationals and Will be at this years nationals for our 6 gold award. Can be seen between Wednesday and Saturday in person.
Original paint with the exception of bumper fillers from Gbodyparts replaced a couple years ago.
I have replaced heater hoses and radiator hoses but retained originals, have replaced brake pads/shoes again retaining originals
All fluids replaced, coolant, transmission, rear end, power steering and of course oil.
Brake fluid changed every year for the last 10 years, so the power master is working great.
Fuel tank, sending unit and pump replaced a few years back due to sitting, all working like new now. Injectors cleaned and check good.
Timing gear replaced with TA performance double roller and cam thrust spring upgraded to gm roller spring.
Valve springs upgraded. Comp 980s
Oil pan gasket, timing gasket set, and transmission pan replaced with gm nos gaskets. Valve cover used Felpro.
$39,500
Thumper
608
42
28
Kentucky
1986 Grand National
Ordered new with seven options
Front carpet savers
Rear carpet savers
Posi
Lighted vanity mirror
Rear defroster
Am/fm only radio
Tilt steering
Hardtop, fixed antenna, crank up windows
Have documentation, order sheet, replica window sticker, all glove box paper work along with original Life Insurance paperwork only offered in 86.
Will post some pics in next couple days.
Thumper
608
42
28
Kentucky
974ABD4A-6010-40F2-BE41-D866124C11A4.jpeg27801934-D289-4C97-A72B-F2625648D30C.jpeg6D35633C-0F07-498C-936E-6C7621AB251E.jpegDC5B7A6C-D2AA-4D41-B96F-7A2CAC7EFAF8.jpeg974ABD4A-6010-40F2-BE41-D866124C11A4.jpeg27801934-D289-4C97-A72B-F2625648D30C.jpeg6D35633C-0F07-498C-936E-6C7621AB251E.jpegDC5B7A6C-D2AA-4D41-B96F-7A2CAC7EFAF8.jpeg67257B96-0577-4A75-8E35-8190BE6777EE.jpeg26FE461D-DCAF-40BD-B484-CF6169EBBE4E.jpeg9535E432-EAB6-4715-8E13-08A1E753E5CD.jpeg
Stock exhaust has been upgraded to the best, Atr 2.5 real 304 stainless with pit bull stainless mufflers. ( do not have original exhaust)
Highway stars reproduction intercooler hoses replaced weak originals (originals kept and will go to new owner)
Thumper
608
42
28
Kentucky
It appears by paperwork, 10 options added that deleted 3. Second photo of order sheet.
Thumper
608
42
28
Kentucky
Making a change so to make more original in concours show, car will have New highway stars stock replacement exhaust system installed. Atr exhaust will be an option to the buyer.
reggie44
333
13
18
Thumper, not sure if you have already purchased the Highway Stars exhaust but you might wat to check out Gardner Exhaust's stock replacement system - it is more accurate then the Highway Star's system with the exception of the muffler. The Gardner Exhaust system has the actual same as factory crimped bends on the front mid Y-pipe, over the axles pipes and tailpipes and they are the proper OD. The Highway Stars system is all mandrel bent which yes it looks pretty - but - is not factory correct if that's the look you are going after and is a larger dimeter pipe. Gardner Exhaust spends a incredible amount time doing all the crimping manually and by hand - it's a very labor intensive job but it is correct. The Gardner Exhaust transverse muffler does not have the GM or the 2nd gen part # stamped in the casing but it does have the FIXTURE CHECKED sprayed on the muffler. I would suggest you check them out as well as a option before you pull the trigger on the Highway Stars system.
BTW - you have a beautiful car and I love it with the crank windows and the ATR system on it!
Thumper
608
42
28
Kentucky
Thank you reggie44,
You are correct on info between the two exhaust systems .
I did talk to Gardner about their exhaust system.
Both have there pros and cons .
Thumper
608
42
28
Kentucky
We’ve shown above car in concours at the 2019 GS Nationals, we are happy to have scored 398 out of 400 possible points. This is our highest score of the 6 gold awards over the past few years.
Thumper
608
42
28
Kentucky
Thanks Reggie.
My wife and I got to busy enjoying the event, on the way home she said darn, forgot to take pics. Oh well. Still had lot o fun.
SS/GN
2,190
312
83
55
Buyer beware! This car is better than the pics, buy with confidence. Bill and Missy are just real good Buick people and this car shows it. I have seen this car a few times and I am very fussy, you wont find any better and what Bill says is 100% the truth and he is very knowledgeable. Who ever buys this car gets years of experience and I know Bill would help you out down the road with advice or concerns. Good luck to both sides.
Hunter Dog
14
3
3
56
Evansville, IN
I agree 100% with SS/GN. I have seen this car in person and met Bill and can say this would be a great car for someone wanting an 86GN with low miles and well taken car of. Bill is a solid guy as well. Good luck !
