14 bolt GN1 heads, lifters, Champion intake
forcefed3.8's
Buckeye Bullet
14 bolt GN1 heads fully ported. These are the latest casting from Champion. They have 1.9/1.6 valves. I ran 8.76@154 with these heads. They are ready to run and set up for a hydraulic roller. The intake ports are ported higher than the fel pro 1200 and the chambers have been unshrouded. They will require a 4.02" bore gasket and a raised port intake port gasket. I have had these heads flowed as well as 2 sets of GN1r and fully ported TAs for comparison.
I am selling with a set of T&D Jessel style rockers 1.65 ratio. They are in perfect condition. $2700
Champion intake, ported runners, external regulator fuel rails 1/2" plenum spacer. Has had some ports added that can be plugged off if not needed with pipe plugs. Off center application. This is the Champion casted intake, not the ported stocker. $650
Heads will be set up with roller cam springs and titanium retainers.
