heat them up a little bit to clean them off , get them too hot and they dont stick as well
87 hit good on both stock bars, airbags (15pass ,7 driver) and southside style(no rubber bushing ) lowers and adjustable heim end uppers .
i tried no front bar and did worse , now I have the HR parts HD rear bar and no front bar and bags empty
leaving off footbrake with about 3-5 psi , tires at 17 psi was getting 1.6 to 1.65s went to 22lbs and got a 1.588 and top end mph went up
on the slicks right now leaving harder Im only getting 1.65-1.75s
86 stock uppers , boxed in stock lowers , OE bushings, HR parts HD sway bar
off transbrake at 3750 rpm (7-8 psi) has hit 1.50s pretty consistent ,
, 17lbs in tire for the 1.50s but i had 22 1/2 psi when i hit the 1.522 and gained at the top due to the added air presssure.
this car has 6 point roll bar and with a dfi on slicks was doing 1.40s but with alot more launch boost
