Jul 10, 2006 #1 S stk6bngr Member Joined Dec 24, 2004 Messages 168 anyone running 18x10's without notching the frame or rolling the fender lip???
Jul 12, 2006 #2 X xcessiv6 Boom Tube Joined Sep 12, 2005 Messages 778 I run 18 x10's plenty of room on the frame tires 275/40/18 need to roll lip.
Jul 13, 2006 #3 T TwinyTwin Member Joined Jan 31, 2005 Messages 393 xcessiv said: I run 18 x10's plenty of room on the frame tires 275/40/18 need to roll lip. Click to expand... Do you have any pictures?
Jul 13, 2006 #4 R RUQWKNF27 Active Member Joined Apr 3, 2003 Messages 1,892 are you running 4.5 BS??? Also what Bs do you run on front?? I assume you have 18x8's on front!!!
Jul 14, 2006 #6 X xcessiv6 Boom Tube Joined Sep 12, 2005 Messages 778 I have Custom Component Wheels Front 18x9 backspace 4.75 Rear 18x10 backspace 4.75
Jul 14, 2006 #7 L lsahali New Member Joined Jun 23, 2006 Messages 1 What size tire do you have on the front? Do the fronts rub and is it stock suspension?
Jul 14, 2006 #8 X xcessiv6 Boom Tube Joined Sep 12, 2005 Messages 778 245/35/18 with BMR upper and lower control arms with QA1 coil over system No rubbing but the front suspension is stiff I went the bigblock springs so i could adjust ride height,
