Toby_Goodmk
Test Fit officianto
- Dec 9, 2011
Started the electric fans setup today. It starts with a 99-04 Dodge intrepid dual fan setup. A piece of 3/4" angle iron and a welder
Made a mock setup with some spare parts in the basement to make sure the measurements for the bottom brace is correct.
Toby I'd like to commend you on a wonderful job take your time and keep up the great work. I am an original owner of a 85 and you are going to feel great when you bring it to Bowling Green for the Nationals. When do you find time to work to pay the bills? Good job! I currently have a t62/66 turbo being built for my car hope to get it next week sometime. Trying to get it in the 10's. John ,I live in Bowling Green please keep us informed.
Make sure to grab the correct rubber bushings for the 3 core setup
Brace looks accurate
Brace all welded up and ready to go, if the relays come in tomorrow Ill get it wired up. THese two fans running are like a beechwood turbo prop
I cut the bottom mounts off, and make a special bracket for the top two to the radiator support
Are the bushings for under the radiator or at the top between the support and the radiator?Not hard at all to wire in the fans, basic electric 101. As for the bushings, i have parted so many cars, i have buckets of them
Did you use a Dual Relay Fan kit from JEGS or SUMMIT? I like the clean installation. You did a ROCK STAR job on this car... Keep up the good work and ENJOY the seat time ;-)Not hard at all to wire in the fans, basic electric 101. As for the bushings, i have parted so many cars, i have buckets of them
Just got done looking at your build Toby. I have the exact same car which I'm doing a full frame off resto on. I'll be converting to the 87 drive train as well. Always loved the Leer Seiger interior.
Yeah Toby, that's me. I didn't weld on the frame, but I will be installing the bolt on braces that connect the upper and lower rear control arms, the braces for the shock towers, and the front triangulated braces too. Once the body is back on the frame, I'll be welding in the back seat brace.If it is the one with the grey powder coated frame, you have a VERY nice build going on there. I saw it last night prowling around. Keep up the great progress. Make sure to stiffen the frame where you can and put the GNX back seat brace in, it helps us with the ttops and large HP cars.
