1986 Buick GN
MOTOR:
231 V6 3.8L/bored 30 over/o-ringed block/steel main caps
TRW pistons
Precision 218/222 cam
M+A Stage 3 aluminum heads(0 miles)
Trickflow pushrods/ARP studs/STage valve covers/K+N breathers
Crane roller rockers
PT-63 Precision turbo
Champion ported lower intake/Precision plenum
75mm throttlebody
Precision front mount intercooler w 3" pipes
Tial wastegate
Big Mouth cold air kit w powerstack filter
RJC race pulleys
turbo saver/remote filter
mini starter
FUEL:
Metco fuel cell
Aeromotive pump/10 + 100 micron filters
#8 feed and #6 return steel braided lines w/ AN fittings
hotwire kit/#83 injectors
Accufab billet regulator/modded fuel rail
EXHAUST:
ported stock headers/2.5" crossover/3.5"custom downpipe/test pipe
3" single shotexhaust w/Dynomax Race Magnum
TRANS:
rebuilt 200 4R/Performance Trans aluminum XTREME deep pan
ARt Carr shift kit/Art Carr 9" non-lock up converter(3000-3200stall)
Hurst quarterstick shifterw/coverplate
B+M supercooler/poly mount/Aluminum driveshaft/driveshaft loop
Hurst line lock
Elctronics:
F.A.S.T. engine management(sequential w/wideband O2)
Innovative multi-stage boost controller
guages=monster tach/air fuel/boost/oil press/temp/knock/fuel press/volts
ESP coil pack/MSD wires
Optima Battery (trunk mounted)/on off switch
COOLING:
F-body aluminum rad/Jazz overflow
Ramchargers dual fan kit
BODY:
Fiberglass hood/trunk/front and rear bumpers/fillers
aluminum bumper mounts/aluminum rad support/aluminum rear firewall
BRAKES:
vacuum brake conversion/Postons big shoe kit/S-10 wheel cylinders
aluminum drums
SUSPENSION:
BMR upper and lower rear control arms/poly bushings
BMR Xtreme anti-roll/sway bar
dual air bags/Eibach springs/Lakewood shocks(90/10's and 50/50's)
Tubular front upper A-arms
OTHER:
LPW rear cover/girdle
Weld Draglites w/ new tires
BFG Drag radials
Grant carbon fiber steering wheel/S-10 manual steering
manual windows/locks/seats
Extra parts included:
S+W RACE CARS 8pt bar with rear pro bars
used 2.5" dual exhaust Hooker
RJC power plate/instant center brackets/many stock takeoffs:
power steering/trunk/driveshaft/AC stuff/sway bars/control arms/etc..
I hate to sell but lost interest and have no time right now.Getting out of GN's for now.Lots of money and time invested.ASKING $11,000 OBO
email for pics and info at lstetler@aol.com
also call me at 610-804-2303
THANKS ,Tony
MOTOR:
TRW pistons
75mm throttlebody
Tial wastegate
RJC race pulleys
mini starter
FUEL:
Metco fuel cell
EXHAUST:
TRANS:
Hurst line lock
Elctronics:
COOLING:
BODY:
BRAKES:
aluminum drums
SUSPENSION:
OTHER:
BFG Drag radials
THANKS ,Tony
