  1987 Buick Grand National
 1987 Buick Grand National$19,995
This is an immaculate matching numbers car. A 10 second car that gets 21 MPG with the ice cold A/C on. Over $40,000 invested. Book with full documentation of car from the build line to latest mods. This car has won several car shows and is fun and reliable to drive. 34,700 mileage.
Paint and Body: The body is straight with no fillers. Never been in an accident with a clean carfax. Never driven in the rain. You could eat off the undercarriage. Paint is new; black with a red pearl. Absolutley beautiful in the sun!
Interior: Immaculate all the way through the trunk. It looks new and has been cared for. Full compliment of autometer gauges ( air/fuel, oil pressure, fuel pressure, water temp., monster tach w/shiftlite, boost, scan master). Stock appearing stereo head unit with Rockford Fosgate sound system ( 2 12’’ subs, components: 6x9’s, 6.5 mids and tweeters, custom stock appearing door panels). X-braces in the trunk.
Motor: 210/215 roller cam, champion ported heads and intake, roller rockers and roller lifters, polished upper, corvette MAF and translator, Razor alcohol injected, front mounted intercooler, T60 turbo, 60LB injectors, Turbo Tweak chip, external wastegate, blowoff valve, and boost controller, cold air kit, racetronix double fuel pump, double electric spals fans for extra cooling
Transmission and Rear End: Professionally build transmission for 600RWHP with billet parts and line lock, 2800 Pats stall converter, external transmission cooler with electric fan. 3.73 Auburn posi unit rear end with GNX aluminum cover.
Chassis: Edelbrock upper and lower adjustable control arms, 90/10 adjustable front shocks, 70/30 adjustable rear shocks, S-10 dual piston vacuum brake conversion, large powder coated front and rear sway control arms. Under carriage is themed in red and grey powder coat.
The car comes with two sets of tires: stock GN rims with 26” Mickey Thompson Street ET’s for a stealth look and Centerline Draglites with Skinnys on the front and 28” Mickey Thompson Street ET’s.
All original parts saved.
I can email pics of the new paint which look spectaculor. TB wont let me add the new pic files for some reason.
