1987 Buick Grand National t-top 12,500
GENEJR
1987 Buick Grand National, It is a t-top car with,ac,pw windows
I bought this car with a blown motor, and I had the motor rebuilt. And repainted the car and had turbo rebuilt.
I have the lap top for it. I bought a intervator wide band. But have not finished putting it in. The car is a little dusty in the pictures. It has been sitting for a month, I just put new battery in it.
Every ball joint, bushing,springs and shocks, tie rod ends are new. call me at 623-696-5621 gene for more info.
# Matching 109 block .020
TRW pistons
comp cam 206/206 roller cam
comp cam roller lifters
two steel main caps
Engine tie down strap
Billet fuel pressure regulator
MSD DIS 4 PLUS Ignition
#75 injectors
maf translator + ,ls1 maf
3” intake with KN filter
72mm throttle body,upper plenum
T 70 turbo.
(TIAL) wastegates
3" stainless downpipe
boost control
big precision stock location intercooler
2 electric fan
ATR exhaust
walbro 340 fuel pump
Drive shaft safety loop
Boxed rear control arms upper/lower w/ poly bushings
Rear end 3.42 ratio
Air bags
Transmission-Turbo 200r4 (NEW) Rated to 1000 hp
9.5 “ precision 3200 stall converter
Deep pan
Trans brake
Remote filter & cooler
Autometer gauges include:
Oil pressure
Water Temp
Boost Gauge
DRIVER UPGRADE FOR BUICK ECM
EXTENDER EXTREME CHIP
Innovate XD-16
Turbo Buick Power Logger Scan Tool
Stage 2 GN Boost Cooler water-methanol
new polybushings front and rear
all new brake calipers,rotors
upper/lower ball joints
dual airbags
new shocks.
I live in phoenix arizona. The title is clesn no salvage, and it says 120,000 miles on the title.
