1987 Factory GN Parts
Here's some factory 1987 parts:
BODY/EXTERIOR:
pass side front air dam, driver quality, decent but some scuffs, $40 shipped.
full length air dam, nice shape other than 3 sections of small scrapes/gouges, $90 shipped.
1 oem 1987 rim, some surface rust, 2 small dings on lip (shown in pics), $30 PLUS SHIPPING!
set of front bumper guards, one rubber has a 1/2" chunk missing out of it, need paint, $30 shipped.
Clear front bumper lenses (turn signal) set of 2, driver quality, some scratches/cracks, etc. but its all intact, $35 shipped.
INTERIOR:
map light, no center plastic cover, $25 shipped.
both upper door panels, grey, no rips/tears, window rubber molding included, no straps, $150 shipped.
GM seat belt set, grey, complete 10 piece front & rear set, $130 shipped.
New gray foam backed headliner fabric, for hardtop, $50 shipped.
console lid, not ripped but some scuffs (the 2 upper corners you see in pic), $30 shipped.
hi-rise console with lids, 2 doors/sections, needs repaint (was red, now mostly grey), small crack in leather on front section, MAKE OFFER.
ENGINE:
water pump, looks new, not GM, $40 shipped.
factory type headers (both) & crossover pipe, no cracks, MAKE OFFER.
driver side header, needs weld on #5 (cracked). MAKE OFFER.
cam sensor, new in bag, not GM, $130 shipped.
cam sensor tool, $35 shipped.
crank sensor assembly (caspers) $50 shipped.
stock piston set, w/ rings, pins. MAKE OFFER.
lifters/springs/valves, stock used, MAKE OFFER.
stock turbo cover, no rust, $50 shipped.
heater hose kit (4 pcs, new in bag) $40 shipped.
OEM oil fill tube & cap, $20 shipped.
idler pulley (belt tensioner) & bracket/mount, used great condition, $75 shipped.
factory in-tank fuel pump, used, $25 shipped.
stock cam w/ gear, $50 shipped.
used coil pack, $35 shipped.
factory radiator, $90 shipped.
SUSPENSION:
1 rear lower control arm, $35 shipped.
set of rear axles, $130 shipped.
set of stock calipers, rotors, MAKE OFFER.
set of stock a-arms, MAKE OFFER.
rear end yoke, $25 shipped.
driveshaft (loop) fact. strap $20 shipped.
set of 4 upper control arm bushings, new GM #15980176, $25 shipped.
Paypal / money orders.
"shipped" means lower 48 USA! (others will be more).
MORE PICS AVAILABLE ON REQUEST!
WATCH FOR UPDATES BELOW!
Looking for TR GN diecasts?
http://www.turbobuick.com/forums/buick-diecast-collectables/330202-rare-buick-gn-gnx-tr-diecasts-sale.html
Interested in the passenger side airdam, can you post pics of it please?
Thank you,
-DD
Thank you,
-DD
1. overall
2. outside lower corner
3. inside lower corner
for the guy who asked me about the headliner:
Interested in this. Can you please provide more close up pics?
I wouldn't consider them "mint" but they are nice. no grease stains. Maybe a quick cleaning & they'll be really nice looking.
the drivers side (1st pic) has a slight wear mark (where you'd rest your arm while driving, about 3-4" long).
on the last pic, the dark spot is a shadow from the flash.
anywhere else you want to see?
I will take them. Please PM me your payment info.
Can you post a picture of the clear lights thanks.
drivers side is worse than passengers.
pass has 1 crack (about an inch, runs top to bottom, the crack is about 4" over from the left (on the lens itself) in the first pic, {its the bottom lens})
the 3 close ups are the drivers side.
like I said, "driver quality" def not for a show (or real nice) car.
Here's some pics for those who requested:
1. idler pulley (belt tensioner) with bracket/mount, used great condition, $75 shipped.
2. set of 4 upper control arm bushings, new GM #15980176, $25 shipped.
3. used coil pack, $35 shipped.
pics:
Are those front A-arm control bushings?
I was assuming rear if they are rear I will take them, sorry for the confusion.
yes, they are FRONT a-arm bushings (not control arm). my mistake when listing, sorry.
(set of 4 upper control arm bushings, new GM #15980176, $25 shipped.)
