1987 Turbo T, Car Craft RSE winner
DrBuick
1987 Buick Regal T-Type Winner 1998 CarCraft Real Street Eliminator
New Price $21,500
VIN 1G4GJ1179HP426989
117,000 miles, always garaged, now in climate control shop, still tight feeling, AC, PDL, PW, tilt steering, delay wipers
ENGINE: 950 miles, stock 109 block bored .030, Weisco forged pistons & rings. RJC block girdle, ARP main & head studs, iron heads ported by Lozano Bros Porting (engine shop chosen by Buick to build Buick engines for IMSA GTP lights class which Buick won in 1999, they also helped with the turbo Indy engine that Scott Brayton used to set the all time qualifying record at Indy) with ceramic coated Ferrea valves, O-ringed block, stock head gaskets, stock intake ported with EGR boss removed, Precision plenum with RJC distribution plate, stock throttle body enlarged to 62mm, stock resized rods with ARP bolts, Eagle 4340 forged crank, standard size main and rod journals, TA grooved cam bearings, neoprene main seals, new timing chain cover with extensively ported oil pump, RJC oil scraper, Rollmaster timing chain, Bullet billet 206 degree hydraulic roller cam, 109 deg lobe center installed @ 106 for 3 deg advance, .512” lift with TA 1.6 ratio roller rockers, RJC valve cover spacers, RJC extended oil pickup tube spacer, “109” injectors (43 lb), Turbonetics stage V turbo (60mm) with ball bearings (it spools up very quickly), stretch stock location high efficiency intercooler, Poston ceramic coated headers, Translator Plus, light weight mini starter, fuel pressure gauge on fuel rail, new type II coils on a new module, engine torque strap, Kenne Bell ram air system, 3”LT-1 mass air sensor, ceramic coating on valve covers, intake, and plenum, Amsoil 20w-50 racing oil, Precision remote oil filter, SMC latest alcohol injection.
TRANSMISSION
Built in June 2004 by Mike Kurtz @ Century Transmission in Houston @ 109803 miles on car. Precision Industries Vigilante converter @ 116070 miles with 3000 rpm stall, Amsoil ATF, plate type trans cooler
REAR
Stock 8.5 with 3.42 gear and synthetic lube
EXHAUST
Poston ceramic coated headers, Terry Houston 3” SS downpipe, ATR SS 3” single pipe with crossflow muffler and two 3” tips, catalyst deleted
COOLING
BeCool aluminum radiator, 160 thermostat, Spal dual fans, Evans NPG waterless coolant
CHASSIS
Drive shaft loop, stiffening bars under hood from fender to radiator support (powder coated), stiffening bar between frame rails at front swaybar, stiffening bars underneath from crossmember to frame rails, GNX frame to body bushings, aluminum bumper to frame connectors
SUSPENSION
Front springs shortened, rear springs by Hotchkis, Del-A-Lum front U&L control arm bushings by Global West, Bilstein shocks, rear lower control arms by Global West with front heim joints and rear poly, front 36mm hollow sway bar, rear 7/8” custom sway bar by me
BRAKES
Stainless braided Teflon brake lines, Hawk HPS pads, Wilwood proportioning valve, Vacuum booster conversion, aluminum drums
WHEELS & TIRES
Complete Custom Wheel (CCW) 3 piece with 20 ARP bolts, very light weight, 17x10 front, 17x11 rear, 4 7/8” backspace, Custom “T” centers
Goodyear Eagle F1 GS-D3, F/R 285/40-17 / 315/35-17
BODY
Shaved T-Type header panel emblem, shaved door mirrors, GNX fender flares with front inner fender cut way back and filled with flexible rubber, rear inner and outer fender cut back and filled, GNX front fender louvers, GN truck lid spoiler, GSCA fiberglass bumper inserts, new rubber bumper inserts and door window trim, Hella headlights, fresh show paint by Dynamic Conversions in San Antonio, no rust anywhere
INTERIOR
Wink 5 panel mirror, steadfast armored steering column painted blue, 4 guage cluster with Ultraflow vacuum/boost gauge, Cyberdyne water temp and oil pressure, and EGT gauge all in a blue housing, knock sensor (that’s right: blue), Alpine CDE-134HD CD/HD radio receiver, MTX Thunder ( 0ne of the last ones made in USA) #564 amp with 70 watts RMS x 4 @ 4 ohms, Kenwood 6x9 rear speakers, Scan Master in console, 145 MPG speedometer with a true reading odometer ( most of ‘em are false), cloth buckets with console
MISC
Optima red top battery mounted in trunk, New Red Armstrong XP Plus pump and volt booster, Casper’s hot wire kit and ground kit, J Carter chip, GM electronic key security system
Dr Paul Wilke
Home 210-651-0836
Office 210-495-5588
Cell 210-827-2957
As you can see these pictures were taken in 2008. The car has only been driven about 400 miles in that time. It has a new Alpine stereo. Located in San Antonio, Texas
Looks great Doc! Wish I had the funds...
That is the exact color in a TB I am looking for.
GLWS..
I just found Richard Lasseters' fair market evaluation of my car back in 2008 when it had 400 less miles than it has now. His opinion was $26,800 to $27,650. Maybe I should raise my asking price?
