The car is kept in a garage and barely used.
It has some rust by the drivers side rear tire.
Asking $11,000 or best offer.
New York, Long Island.
87 Turbo T 99,000 miles.
Maroon exterior and maroon interior.
The engine was rebuilt at 89,000 miles.
The transmission was rebuilt at 89,000 miles.
The rear was freshened up at 90,000 miles.
TA 60 turbo. About 1,500 miles on turbo.
Terry Houston 3” down pipe, 3” exhaust from turbo to rear, Dynomax mufflers.
Drive shaft loop, Poly motor mounts.
Nitto drag radials on rims. Duttweiller neck on stock intercooler.
SMC Enterprises alcohol kit.
Suspension: KYB shocks, Passenger side rear air bag, Pinion Snub, Stabilizer bars behind rear set.
Gauges: Scanmaster, Water Temp., Oil pressure, Boost gauge on pillar.
Engine: Changed alternator and starter a year ago. New battery. New serpentine belt. New plugs. New O2 sensor. The compressor should be changed in the near future. It’s works, but makes some noise.
36lbs injectors. K&N air filter. Translator Plus MAF. LT-1 3” MAF sensor.
Any questions, I can be reached at justa231@yahoo.com or 631 988-5450.
Nick
Nick
