1936fordturbo
- May 14, 2008
1987 Turbo T
Just over 90000 miles. Nice Clean Driver Quality Car does have some dings. Never a rotted out mess. T-Tops, Power Windows and Locks, Tilt, Cruise, 3.42 Posi, Buckets & Console, Knock Gauge, Boost Gauge, Oil Gauge, Coolant Gauge, TE-44 Turbo, 60lbs Injectors, Billet Fuel Pressure Regulator, Fuel Pump Wire Upgrade,Extender Chip, 10mm Plug Wires, 21 Row Intercooler, Alky Control, Volt Booster, 3" Down Pipe, Full 3" Exhaust, Billet Vacuum Block, A/C Convert to 134A, RJC Throttle Body Plate, RJC Rear Motor Plate, RJC Boost Controller, RJC PCV Valve, Fresh Trans Rebuild By Russ Madak, 3000 Stall PAT'S Converter, Tires are Like New, New Ball Joints, New Tie Rods, Idler Arm, Center Link, New Steering Shaft & Rag Joint.
Asking $15000 Negotiable
Here are some Pictures.
Call Me if You have any questions.
David 330-four-one-six-8900
Located in Brunswick, Ohio 44212
