Black on black. 48k miles. I've owned the truck for about 2 years and did some minor mods during that time. When I purchased the truck, it had a fuel pump and boost leak issue that i chased for a little while. I upgraded the pump and throttle body and it runs awesome. Also has new master cylinder. I put a new heater core from GM in it, updated the resistor, blower motor, and switch relay. The truck is super clean. Orignal paint, cladding, wheels, exhaust, etc. Inspected in a PA until June 2013.
-Stock Exhaust
-Stock untouched bottom end
-Stock stock untouched heads
-Walbro 255
-QA-1 12 way adj. rear shocks
-Energy Suspension greasable swaybar bushings
-RPM 52mm throttle body
-RPM vacccum brake hose with AN fitting w/ boost tap
-RPM cold air intake (updated with PCV bungs)
-RPM charge pipe
-RPM fuel pressure gauge
-halfast enginuity EGR delete
-Innovate wideband (all electrical ran, needs o2 bung welded into test pipe or aftermarket exhaust, your choice)
-VDO 30psi gauge
-Hot wired intercooler pump
-New cap and rotor
-Taylor 8MM wires new plugs
The truck should easily run mid 13s, and with a chip and exhaust in the 12's. All the "Josh Straub reliability tricks"
$14,000
I may also be interested in trades for any Turbo Buick, Turbo Trans AM, or Syclone! Let me know what you have!
I can be reached at 7248430771
-Stock Exhaust
-Walbro 255
-RPM charge pipe
-VDO 30psi gauge
-New cap and rotor
$14,000
