1995 Master Window Switch Removal
Throck
Need help removing the master window switch from the driver's door 1995 Buick Park Ave Ultra. I am able to remove the trim piece that holds the window, seat, and mirror switches from the arm rest. I can remove the wiring harness connector from the bottom of the switch but cannot figure how to remove the switch from the trim piece.
Any help will be appreciated.
This is my first post so if I did not do it right, any pointers will be appreciated
05-04-2012 PROBLEM SOLVED
The keepers that hold the switch in the Switch Trim Plate are located at the front and rear of the switch. Slide a thin blade or screw driver between the switch and the pocket of the trim plate it is in and gently pry the edge of the trim plate away. The switch will pop right out.
Thanks to all those who looked at this to see if they could help.
SWITCH PLATE STILL IN DOOR THEN CLOSE UP OF TOP OF SWITCH​
BOTTOM VIEW OF SWITCHES​
WIRING HARNESS CONNECTOR REMOVED​
BOTTOM OF WINDOW SWITCH​
SIDE VIEW OF SWITCH​
