I saw backfire on your 11.3 pass, are you hitting the limiter on the shifts?, if you are, back off on the shifting points a bit the car will go much faster, i also see your car having some major body flex issues during launch, if you have not upgraded the suspension in the rear i think its time to upgrade to a HRswaybar, it will make a whole lotta difference in your launch and keep the body straight, by the way the pump is a great idea and it works really good by keeping negative crackcase pressure thus preventing leaks from happening or blowing out your seals, if you dont mind me asking where are you dumping the outlet of the pump and what is the part # for that particular pump you bought?
