BlackBeauty
- Dec 15, 2001
I need tips please. As the subject says, I went to the track last night for the first time with this car. My car is set up for 12's (I believe), I just had to figure out how to launch it. Here's my set-up to give an idea:
stock turbo/ic/injectors
adj. fpr (45psi line off)
Walbro 307 hot-wired
9" K&N
adj. wastegate rod (24psi)
Thrasher 92
Hooker cat-back
SMC alky kit (spray on 15psi, pump speed 8)
BFG DR's 275/60/15 (30psi, mounted on stock wheels)
I believe that's all, performance-wise. Anyway, on my 1st and 2nd run, I launched at about 1lb. of boost, cause I didn't want to power brake for long to overkill the tranny. I would just stand on the brake, and when the tree starts counting down, then I would floor it and go. I ran a 13.996@100.81 . So that's pretty far off from what I was hoping for. My 60' was 2.2, not good. On the 2nd run, same thing, except I raised fp to 46 line off, got a 13.81@100.58. So on the third run, since I read about you guys launching with anywhere from 15-25psi
, I did a good burn-out before approaching the line to heat up the DR's, then built boost to 5psi and launched, spun half way down the track. I had to let off to stop spinning, then got back on it. 60' 2.398, ET 16
. That's when I decided it was time to go home, since I was being bugged about not having a helmet (why do I need one, I have a 16 second car). The reason I bought the DR's was so I could HOOK. What do you all suggest? Should I run lower tire pressure (didn't think of it at the time)? Airbags (I don't have posi)? Thanks.
9" K&N
Thrasher 92
Hooker cat-back
