Reviewing some data logs for n/a SBF 427 with FAST Classic. From 5k rpm up the lines for kpa/vacuum are zig zagged thru 6k rpm shutdown. RPM likewise zigs that last 1000 rpms. It is very pronounced and eratic when overlayed in the VE table playback.
This was on a DTS engine dyno. The HP/Tq curves look smooth enough though it definitely peters out at 5700 and short of what HP I was expecting.
EGTs were 1250-1400 with couple cylinders with 1200's and couple with 1400's - any evidence here between a cold or hot cylinder? Standard full runner EFI intake.
Is this a valve or valvetrain thing that effected the vacuum signal or just something with the dyno?
Any $.02 is appreciated.
