ok guys here it goes..heres more info cause i need some of your help...first its a bq trans 85 tr..so you know...i adjusted the tv cable to where i now have decent shifts..tv cable is on the tight side.to give you an idea.....so my 3-4 shift is too long..to give you an idea....1-2 at 14mph
2-3 at 23mph..then it feels as if it stays until 45 to hit 4th this is at normal driving/ highway...what can i do...im thinking of valve body and governor repairs and checks..but can i do vb repairs without taking it off..replacing valves and seals and such or when i pull a valve are other items or check balls fall out and really be in trouble..so help me out here fellas...thanks vinny
p.s. maybe chris718 can chime in cause i might just go down and see him let him drive this and check for me or what not
