2.3 volts instead of 1.6
speedskills
Seniór Member
Just installed razors alky kit and I don't know if thius is an issue or not. I'm reading 2.3 volts on the green map wire instead of the stated 1.6 volts. The system seems to work fine. Is this a problem?
yeah you have to install the new 3bar map inplace of the 2bar :)
atleast you read and followed the instruction portion to check the map voltage
